Yamaha T135i (Greek name of LC135) Clutch Problem
Alex40
Hello everybody!!!
Greetings from greece!!!
I would like to share with you a problem that i have with my Yamaha T135i.
I bought it new at 2014 and i have no reason to complain about it except its clutch...
I tried lots of times to regulate the clutch from the regulator screw at the left of the engine as the manual says with no results...it kicks like a donkey at every gear shift and i cant find the reason why...
Does anyone know what is probably the problem about it so i can fix it by my self or is some kind of a damage that needs to be fixed by an expert?
Thanks for your time reading my post!!!
Alex40
I understand...
I might have silly concerns and maybe that is the reason that noone cares to answer.
Thanks for your time again....
Does anyone know how to erase this post?
Alex40
Problem solved...
I fixed it by my self, regulating-adjusting the screw at the left side of the engine (near the clutch lever).My opinion is that this screw can only be adjusted by the driver multiple times till discover the right position that allows shifting smoothly and with less kicking...
Always helmet on your heads my friends!!!
Ride safe!! Enjoy the moments!!!
Alex40
By the way, greek mechanics do not know how to regulate the clutch.
They do not give particurarly care to the mopeds as they give to more expensive scooters and big motorcycles...
