suplado010
ayos lang..napakalayo pah sa pagsabog niyan..haha...Naka 15/42 sprocket ako,ayos lang ba paabutin ng 50kph sa 1st gear?90kph sa 2nd?at 120kph sa 3rd?
thats ok bro. im using uma cam now on my shaved block. everything is good. uma has higher lift than cmsNaka 15/42 sprocket ako,ayos lang ba paabutin ng 50kph sa 1st gear?90kph sa 2nd?at 120kph sa 3rd?
for a year I use 14x45 sprocket combi. imagine how low speed is that. 1st gear 55kph, 2nd gear 85kph, 3rd gear 120kph. u r using hi speed combi so your stats will be just fine for the next gears to be easily rev upNaka 15/42 sprocket ako,ayos lang ba paabutin ng 50kph sa 1st gear?90kph sa 2nd?at 120kph sa 3rd?
same lift lang poh cms at uma..thats ok bro. im using uma cam now on my shaved block. everything is good. uma has higher lift than cms
nope... uma is highersame lift lang poh cms at uma..
uhm..ok..nope... uma is higher
how many mm did you shave?thats ok bro. im using uma cam now on my shaved block. everything is good. uma has higher lift than cms
classified sirhow many mm did you shave?
if not using racing cdi, 3rd gear revs limit at 85kph sir.nice thread sir. im amazed by these mods. ride safe
using 14-45 sprockets makes me wonder what rpms your engines running at speed of say 120kph.
watch mode
OMG.hehehestock bore user..
shave .5mm no base gasket, pnp
modified stock muffler. 4th gear, cdi, valve spring, cms cam, clutch spring, rejet stock carb
top speed 150 almost 2km run
rider 115 kl.
thank you sir,if not using racing cdi, 3rd gear revs limit at 85kph sir.
