Stock Look From Out Side.
aydy
Dude, are you still running the PWK 28? what is your current build? I'm running the 57mm setup with UMA high cam (rest stock) and I'm torn between Carbs. On one hand, I want the Yoshi TM-MJN 26mm, on the other hand I want something tested and proven similar to my setup so it would be easier with the jets. Any help would be appreciated.
aydy
Yes it's a pwk 28 but currently facing a big problem.
What's the issue?
I've got a Mikuni 30mm roundslide carb (genuine replacement carb for TZM 150) I haven't installed it due to single throttle design. Would it work with stock throttle grip with a cable change?
sixty-thirty
What's the issue?
It does work but I would recommend to use Uma quick throttle because then single cable installed there is no stop point in the throttle so the throttle cable breaks.
sixty-thirty
What's the issue?
Issue is the pwk and pe is are not originally designed for 4 stoke . When you open the throttle from 0 to 75 percent fast the bike dies .. If you don't wack the throttle like me then it's perfectly fine No issues at all. And of Cux fuel consumption increases alot.
