krux
selling po yung swingarm , rearset ,gas i shocks slightly used ,pipe dbs ,sprocket 14/38 na 415 , ung iba dko pa natatangal update nalang......items are located in sanpedro laguna....
update ko lang== new item cylinder head made by bong velasques/ ported by precision+st1 cams;; head specs by kuya bong.... swap sa stock head add cash nalang....
specs po nito ay for stock bore.....
additional swallow tires circuit tires pro racer 90/80 front and rear.. 90% treadlife
call lang po wala txt....09238795848
e2 na po prize
yung swingarm 3k, rearset 2500 kasama pasenger pegs,gas i shocks 3k slightly used ,carbon fiber orig pipe dbs 3k,sprocket 14/38 na 415 1000(reserved), swallow tyres 2600 pair
cylinderhead add 3k this mod cost me 8k sure this will make your bike fast and reliable for every day use...
wala na tatawad mababa napo yan.... at ung mga pictures actual po yan at latest what yousee is what you get......
ung mga sure na kukunin napo ung item pa confirm nalang po para isang byahe lang ako papunta pacita...
currently staying kc d2 sa pasig......
actual pictures
e2 na po prize
actual pictures
