Parklight Battery Driven And Headlight Stator Driven Diy Diagram
Discussion in 'Electrical' started by bhek_21, Nov 7, 2012.
  1. icemeth
    icemeth New Member
    Apr 1, 2014
    5
    # sir my SMX is AHO and i cant find the yellow/red wire. my SMX is 2013 model/. need ur help tanx sir, Godbless
  2. CesarMontano
    CesarMontano New Member
    Jun 10, 2015
    36
    Cavite
    .. Where i can connect the tail light parklight to battery operated wiring? it appears that the break light is battery operated while the parklight is AHO. My front parklights are now battery operated while my rear park light still AHO. Thank yyou for future response.
  3. kdd
    kdd New Member
    Oct 4, 2015
    4
    hello... is this still the best and effective to convert the park light to battery operated? this tutorial is way back 2011/12.. I am just wondering if there is a new one which is more effective and more safer... thanks! :)
  4. Sidro
    Sidro Super Veteran
    Feb 12, 2010
    6,375
    1,118
    Laguna/Cavite and City of Smile
    @kdd , yes so far. But you need to change you stock park light bulbs into LED type of lights. If not you might end up on drained or low battery problem. This is my set-up for almost 3 years I converted all my lights to battery driven, but replace it with LED's specially my headlight (3LED headlight). So far didn't encounter low battery or drained battery.
  5. kdd
    kdd New Member
    Oct 4, 2015
    4
    thanks Sidro, the tutorial on the first page is for parklight only right? will i encounter a battery drain problem if i only use LED on parklight only following the tutorial on the first page?
  6. kdd
    kdd New Member
    Oct 4, 2015
    4
    hello again, can i use a bosch relay which has two 87 pins?? i cannot find a relay which has a 87 and 87a pin...
  7. Deigvan Narnia
    Deigvan Narnia New Member
    Feb 16, 2016
    11
    Gulibas Bonbon Cebu City
    Sir can you help how to make a switch for my front park light (MX135) I mean if I'm going to on my headlight
    the park light also will do. thanks.
  8. Deigvan Narnia
    Feb 16, 2016
    11
    bro whats the meaning of stator? sorry first timer owner MX 135
  9. Deigvan Narnia
    Feb 16, 2016
    11
    w
    bro, whats the meaning of AHO?
  10. Deigvan Narnia
    Feb 16, 2016
    11
    bro, which part of MC the yellow wire, brown wire and magneto are located?
  11. mcDo
    mcDo New Member
    Feb 26, 2016
    good day sir, hindi po ako sniper user, hingi lang po sana ako idea, bumili kasi ako ng motor, yung bagong mio i 125. gusto ko sana lagyan ng switch. diko alam kung pano. basta pag nag switch on ako sa ignation umiilaw ang park light, and pag nag start na engine umiilaw na yung headlight. kumplikado daw kasi pag fi. pahelp naman.
  12. Purple Devil
    Purple Devil New Member
    Apr 23, 2016
    Thanks for the tutorials...lets get wired.! :p
  13. zurcnai
    zurcnai Super Veteran
    Feb 5, 2010
    271
    11
    336
    Pasig City
    Hi sirs!
    I have a question regarding my SMX135. I put back the yellow/red wire that is connected from the rectifier to the stator. Now, when i ride my mc, charging is 15.5v at around 3k to 4krpm. but when i turn on my aux lights, it reads around 13.5v. then when i turn on my LED headlight, it reads around 12v. Do you think my rectifier needs replacement? Although I am planning to convert it to full wave rectifier but that will require me to replace the stator to the ones for Mio. what do you think? Thanks!
  14. john harold
    john harold New Member
    Oct 20, 2016
    Good am sir bhek_21, is it the same as the mio amore/ sporty wirings?
    i want to be full battery operated all my lights, what should i do?
    very much appreciated any reply, thank you
  15. Dave Aro Bacus
    Dave Aro Bacus New Member
    Nov 21, 2016
    thanks a lot bro......
  16. snypey16
    snypey16 Super Veteran
    Nov 20, 2011
    869
    162
    Pampanga
    sir bili ka ng left and right switch ng mio sporty, may switch ng headlight yun din rewire lang, yung ang ginawa ko sa mio ng utol ko.
  17. snypey16
    Nov 20, 2011
    869
    162
    Pampanga
    buksan nyo po yung ulo ng motor nyo, yung sa may head light yellow wire is located papunta sa switch on ng ilaw, disconnect nyo po yung yellow yung papunta sa switch ay dugtungan mo, tas i tap mo dun sa brown wire papuntang ignition switch/key
  18. Resty Manalo
    Resty Manalo New Member
    Jun 24, 2016
    is it ok for yamaha mio sporty?
  19. Resty Manalo
    Jun 24, 2016
  20. Romeo Ricalde
    Romeo Ricalde New Member
    Feb 4, 2018
    Hi sir,asking lang po how to convert led headlight to battery operated for mio i 125?thank you!
