my front flarings vibrate too much
jhai_o
can anyone help me with these? how can i minimize the vibration of the plastics,, or its better if i can fix it and get rid of the odd vibrating noise, thank you.. :D
goff_d_p
try using an old rubber inner tube, like from a bicycle. it's thin enough to be placed between the two body parts. also, try to make sure you don't pop the screw when tighting it too much. it will weaken the clip the the screw is being secured to. i have this problem, i need to replace all the clips with a better designed clip.
jhai_o
thanx for the help goff!! i tried it just tonight,, then it works pretty well,, thank you so much guys for the help!!
tom snipes
run a belt made of polyester across the leg shield, will solve your old age problem on vibration , done all previous tips but this one is lasting...
raksta
remove all your cowlings! in an instant no more vibration! goodbye vibration goodbye cowlings also heheheehe
YAMAHA_FIAT99
wheel interrior rubber is cheaper
Storm_rider
i also experienced that sir,.. try putting some interior rubber,... i will help a lot in reduce the vibration,..
YAMAHA_FIAT99
yup put a piece of interrior rubber beneath the fairings where you tighten up your screw. they will act like an absorber to absorb the vibration.
jefpoyi
it's nice to see this thread cause i've got the same problem. strong vibration. nakaka manhid tuloy ng kamay kahit malapit lang ang byahe.
any pictures paps how you do it? what's old rubber inner tube?
TSchool
Het Goff, you mentioned designed clips. Can you recommend any? Just had the fairings wrapped and some of the clips are not attaching well anymore resulting in the rattling.
