RACING CDI
1. BRT dual band
2. Rextor v3
3.BRT hyperband
4. BRT Super i-Max
5. TDR
RACING CAMSHAFT
1. YY pang cams
2. Pan asean cams
3. FAITO
4 .FAITO TURBO CAMS
5. Kawahara k2 Cams
6. LHK Cams
7. NCY Custom Cam Profile
8. HISPEED Cams
9. Custom Grind Cams from CAMPROFILE / Yolac Racing
10. STOCK PROFILED BY CAMPROFILE
RACING VALVE SPRING
1. YY pang valve spring
2. Vixion Valve spring
3. TK Valve Spring
4. Kitti Valve Spring
5. HISPEED Special Valve Spring for Spark135
RACING CLUTCH SPRING
1. CRG clutch spring
2. YY pang clutch spring
3. LHK clutch spring
4. FAITO
5. TK Clutch Spring
6. Kitti Clutch Spring
RACING CLUTCH LINING
1. FCCI Clutch Lining for Honda Wave 125 (orange)
BIG CARB
1. 28mm keihin thailand round slide
2. Keihin Japan PE27
3. Keihin Thailand PWK28 (flatslide)
4. Mikuni TM28 SUDCO (for racing use)
5. Yoshimura MJN TM26
6. OkO 26/28/30mm
7. UMA 26/28/30mm
8. WABRON 30MM WITH ACCELARATOR PUMP
BORE UP KIT
1. Vixion block diasil 57mm
2. faito 60mm block
3. Shark 62mm Block
4. CMR 61MM
CYLINDER HEAD (WITH BIGGER VALVES)
1. HISPEED Cylinder Head for LC135 22:24 / 20:22 Valve
IGNITION COIL
1. Racing Coil API
2.namban
3. ULTIMATE RACING COIL
4. ProTec Groundstrap
5. API Ignition Coil
6. PROTEC GROUNDSTRAP WITH CURRENT STABILIZER
7. Faito Racing Ignition Coil
SPARK PLUG
1. Splitfire
2.iridium denso
3.Iridium NGK IU24
4. NGK PLATINUM
PIPES
1. AHM gold
2. YY pang Shorty big elbow
3. YYpang Longy big Elbow
4. NOB1
5. NamBan Circuit Spec
6. NamBan Open Spec w/ bigger elbow and longer canister
7. HISPEED Open Sec for Spark135
8. 4N
9. ECS
10. HGM
11. JAD RACING
12. CLD
13. AHM SPORT SERIES
14. AHM TRI OVAL
15. AHM CF (carbon fiber)
16. DBS
