• Lets Play Games now at YamahaT150 ARCADE
Lc135 5 Speed Sprocket Compatibility
Hood
Guys. I have a Yamaha LC135 5Speed Manual Clutch, with a modified rear wheel. The rear wheel and rear sprocket is that of a Exciter 150. Current sprocket combination is 42/15. I’m looking to change the sprocket set and I want to know what’s the biggest front sprocket I can fit. I heard that a 16T front sprocket is compatible. Is is possible to fit a 17T or 18T.
Also, are there any Exciter 150 rear sprockets smaller than 42T?
man_sate
Hi,
Why you want to put bigger front sproket?
Bigger front sprocket will make you bike feel sluggish and heavier.
Smaller front sprocket will lead to more pickup and lightier.
Better adjust rear sprocket. No need to adjust front sprocket. Use standard front sprocket size which is 14.
Bigger front sprocket use when you install big bore and jackrod.
