Kick start - "TOK!" sound
Discussion in 'Engine' started by mingomz, Aug 16, 2011.
  1. mingomz
    mingomz Super Veteran
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    Tread title is the most direct way I can explain the problem.
    Just this evening I was about to test run my Bike, I cannot use my push start because I have a weak battery already... -- so the alternate way is to use the kick start.
    I tried a couple of times to kick, and it did not work, since my bike was not used for a week.
    I gave the bike a little push (set on neutral) so the engine oil can circulate. then tried again to kick start. This is were I heard like a snapping like sound or to be more specific a "TOK!!" sound.
    That happened when I kicked down and not when the kick start is retracting back.
    The kick start did not jammed or loosen but I am concerned that something might have broke (jammed piston, crank chain snapped, starter gearing lost a tooth.. etc..)
    I tried to feel the kick gently and push it all the way down slowly and the "TOK" sound was gone. tried a couple of times just to make sure and it did not repeat at all..
    Tried again to kick normally and my bike started already.
    Gave it a test run (around half a kilometer) and luckily I haven't noticed any grinding sound...yet..hopefully it was nothing.
    I'm a little paranoid now since I was not paying attention even when I was on stock block where you could feel the kick start cranking up the starter assembly. Is it by 1/4 or 1/2 when kicking/pushing it down? cause I observed mine, you could feel it cranking i'd say about close1/4 when the kick is depressed down.
    Block is Vixion
    Cams - CMS
    Gearing - stock gearing
    My concern is, what could have caused that? my speculations are-- bike is not on neutral properly, kick start was not retracted all the way properly..
    Just need your inputs/opinions.
    Thanks!
  3. peakabu
    peakabu Super Veteran
    Nov 11, 2010
    3,863
    423
    pasig/las pinas
    ive also experience that when my gas overflowed because of my busted fuel cock..when we open the air box half of the air box was filled with gas and the gas also mixed w/ the engine oil....
    sir try to check your oil and airbox just to make sure...
  4. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    I don't have any air box anymore :)
    I will change my engine oil just to be sure. if there is any large residue or chipped metal.
    thanks
  5. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    I'm guessing the bike was not properly set to neutral. Changed the oil today and used an air blower pointing at the dipstick hole and side tipped over my bike, -- found no metal chips. even on the oil that was drained.
  6. traxxas-modifier
    traxxas-modifier Super LOLO Staff Member
    Dec 17, 2006
    8,047
    4,208
    438
    gensan
    if you are really concerned about it, i suggest to open up your head block
    to see if the valve hits the piston,
    you can check it, there will be a mark on your piston.
    its better to be safe and spend less than P500 or free if DIY
    than having to spend P20k for damages to head and block.
  7. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    Not yet adept in opening cylinder head blocks, I will have it checked to a trusted mechanic just to be sure.
    thanks.
  8. traxxas-modifier
    Dec 17, 2006
    8,047
    4,208
    438
    gensan
    hehe, its simple bro.
    buy torque "click" type wrench
    and follow the service manual.
    very easy...
  9. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    Yap I have the tools already. No guts yet :p let me see tomorrow if I can give it a try.
  10. sniperzzero
    sniperzzero New Member
    Aug 18, 2009
    82
    11
    ParaƱaque city
    Bro, in my opinion it always happen to my Dad's honda xrm. there is always a sound of TOK when in starting the engine using push button e-start and kick start. The problem we encounter is the defect starter. And we repair it to the mechanic (I think Starter gearing) and TOK sound is gone. But it is better to check your engine to your mechanic and I hope your engine is not damage.
  11. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    Problem solved. thanks
  12. jimpie
    jimpie Super Veteran
    Oct 29, 2009
    2,776
    640
    Padilla Antipolo City
    what should you do sir mingomz?.
  13. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    The bike was not properly set to neutral. kids here might have tampered my bike that why when I kicked i heard that sound.
    to be sure I suggest what sir traxx said. to give yo ua peace of mind.
  14. jimpie
    Oct 29, 2009
    2,776
    640
    oh... thanks for info bro. your mind like a gifted-child like admin :)
  15. mingomz
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    haha traxx is way more advance sir. he's the man!
    thanks
  16. projectdimpreza
    projectdimpreza Veteran
    Apr 6, 2012
    263
    13
    136
    Pasig
    this happen to me sometimes when i use kick start. there's a TOK sound.. how did you fix the problem? how can you say that it has been solved? did you open the crank case or replace and parts?
    stock engine here.
  17. speedfreak.com
    speedfreak.com New Member
    Jul 19, 2013
    sir,,my sniper 135 had kickstarter jammed and it woudnt turn back to original position...what could it probably cause???what should i do???please help me sir
  18. xXcastXx
    xXcastXx Super Veteran
    May 3, 2011
    558
    92
    Santiago City Isabela
    Let your mechanic check buddy... Spring got busted
    jangbest likes this.
