Jvt 57mm, 59mm & 62mm Lc Kit For Sniper Chrome Bore W/ Forged Piston
jorick
boss ask ko lang kung saan pwedeng makabili ng 59mm sniper chrome bore tsaka kung mga kano,kung sino pwedeng gumawa.from marikina ko.tnx
audioguy
JVT is going to have new performance parts for the snipers...:)
as of now.. I am not at liberty to divulged any information... hehehe :)
having a new performance parts? would u you have bigger size of block than 62mm for sniper classsic sir:dance: ?
audioguy
we only upgrade once, so you should be sure with the reliable mechanic bro.:) not just anyone na siraniko.. am sure na ayaw mo masiraan during any rides;)
milu
wow!
interested in 59mm...
@ mon2325 sir, if u don't mind.I just want to ask some questions...
what cams size or the lift suitable/compatible with this bore-up kit??
valve size??
carb size??
TIA...
up ko lang ito mga sir
Cesar Ablao
wow!
valve size??
carb size??
TIA...
Cams- stage 2 cams. But depends on your taste. Some cams with low lifts have higher top end than high lift cams. (nu syak lang, stage 1 or low lift cams ak kasla kawahara black cam ta adayu ti byahek, tapos naka babad kinanayon high rpm motor ko)
valves- stock valves are just fine. But if you go with 62mm, use 19-22
carb- 26mm (pero nu syak, ayos akon uray stock carb lang. Rejet lang katapat na dayta.)
milu
This JVT 62mm, is this also Nikasil? Highspeed is Nikasil... Which of the three 62mm bore do you think is better, UMA, JVT, and Highspeed? And why?
Jessie Y
JVT . . . . . Which of the 2 bore kits (59mm or 62mm) perform better on stock cylinder head, stock valves & 28mm carb;
1) long drive
2) fuel efficient
3) top speed
thanks
sniper31
im using 62mm pitsbike. so far so good. no leak no overheat. i tried in 300 km todo 100 kph 165 kph+. my average is 13o kph. no problem using 62mm
Cesar Ablao
1) long drive
2) fuel efficient
3) top speed
thanks
for stock valves, long drives, stock carb (rejet) high revs: 59mm for me. much more safer than 62mm =)
