how to connect a tachometer on a sniper 135 lc?
sniper135lc
i just want to know how to connect a standard analog tachometer or rpm gauge on my sniper. anyone have known? just please give some diagram connection of the 3 wires. thanks
haen
depends on how the tacho reads engine rpm, usually there's two way to connect a tacho :
1. RED (+) to main switch (brown)
BLACK (-) to body / mass
BLUE to orange cable / white cable (pulser)
2. RED (+) to main switch
BLUE to wrap around spark plug cable (induction method)
dark_sniper_15
so what is more accurate between the two methods? and what type of tachometer should i buy if i am planning to do so?how accurate is it? what is the range of tachometer should i used?
thanks for some response.
dark_sniper_15
G
Guest
Guest
all the electric tacho are not accurate, only the mechanic tacho ( Connect directly to the engine by cable) are accurate.
SniperR135
it also depends on where and what brand tach you get. I just installed a Type R on my bike and the Black wire was the Positive to ignition wire, yellow with black stripe was +coil, green was - coil, and the redish brown was light switch. ask the shop that you get the coil from which wire's are for what. it makes it much easier.
y4stroker
nice topic! how about installing yamaha 125ZR (thats what we call it in malaysia, 2-stroke 125cc bike) tachometer? can anyone post some HOWTO? the wirings,etc...
SniperR135
just remember, not all tach's are the same or have the same color code wiring. so it's kinda hard to explain what wire goes to where.
I could explain how i installed my tach, but like i said, the color of the wires are not all the same.
