yup.. un ang gnamit sa wave125 ko nun. 2t. pro msmganda flow ng top1. yan gamit ko sa mx ko. hehehepwede 2t
wag lang brake fluid
p ot sir ilang cm sa bwat fork ang nillagay?yup.. un ang gnamit sa wave125 ko nun. 2t. pro msmganda flow ng top1. yan gamit ko sa mx ko. hehehe
For yamaha sniper classic 62ml each fork, as per manual.p ot sir ilang cm sa bwat fork ang nillagay?
tnx sirBrake Fluid : the word it self Fluid its not oil and Brake fluid is corrosive i think it will easily destroy your oilseals.
We have so many fork oil available market some are share above comments, you can also use gear oil instead, I think brake fluid is not advisable to use on our shocks, just my honest opinion.
I think same with sniper emex front fork
tnx sir55ml-75ml kung hindi ako nagkakamali each fork
it depends. the more oil the fork is more stiffer. i dnt knw the exact bcoz my shock is little bit lower. no need to use racing boy fork stabilizer. my bike is in good handling, i can drive 1 hand at 115km/h.55ml-75ml kung hindi ako nagkakamali each fork
bro IKRit depends. the more oil the fork is more stiffer. i dnt knw the exact bcoz my shock is little bit lower. no need to use racing boy fork stabilizer. my bike is in good handling, i can drive 1 hand at 115km/h.
