Big Carb Jettings / Jet Sizes Recommendation For Yamaha T135
Discussion in 'Tips and Tricks' started by traxxas-modifier, Dec 17, 2009.
  1. man_sate
    man_sate Super Veteran
    Apr 8, 2010
    909
    162
    Kajang
    Rich. Need to change the needle level to 1st.
  2. sixty-thirty
    sixty-thirty Veteran
    May 21, 2015
    362
    94
    156
    male'
    Maldives
    Tried all the needle clip positions but that problem will not go away.
  3. man_sate
    Apr 8, 2010
    909
    162
    Kajang
    Then you need to lower your PJ. Did your piston size is 57mm?
  4. sixty-thirty
    May 21, 2015
    362
    94
    156
    male'
    Maldives
    yes 57mm pistion
    PJ size is 30 main is 110
    how small ? 26 ? 28 ?
  5. man_sate
    Apr 8, 2010
    909
    162
    Kajang
    Your piston is to small for 28mm. My previous setup is like this. Even the plug color is correct still have some sluggish part. Try use small pj if there is problem in starting. Result in this spec is same like standard spec with bigger carburetor.
  6. sixty-thirty
    May 21, 2015
    362
    94
    156
    male'
    Maldives
    what carb size for 57mm piston ???
