Basics Ways For Engine Methods!!
vhadz
2, insert a sucket wrench in the big whole # 16, then turn it, while ur turning it, look inside the small whole, thats where u can see if ur in top end center,, shown below.. there are 3 lines inside
vhadz
tip its hard to turn it or to put it to top end center if the sparkplug is still intact, remove the sparkplug then its smooth to turn clockwise & counter clockwise, ,
vhadz
lossen the manifold connecting ton n cylender head,, release chain teansioner lock, ( diko alam tawag non,) then b4 you, lossen stud bolt located at the cylender head, and then the allen bolt at its side. but first you loosen the bolt from the chassy where the cylender is holding,
wehehe, removed pipe.
loosen or removed chain tensioner gear and its lock!!
vhadz
precedure backwards when ur putting it back together,
tips, when u have attached the bore u pull the chain tensioner to put the piston at the top, double check on tis side where u can see if its on top end center, ayt!!
soon lower engine nmn.. for newbies like me, its all about the heart!! happy modes!!
