Yamaha Lc Bearing Code
Discussion in 'MALAYSIA: LC150 / 135LC owners' started by phl6684, Dec 3, 2011.
  1. phl6684
    phl6684 Moderator Staff Member
    Mar 29, 2008
    4,530
    464
    sungai petani,kedah--->desa pandan,ampang
    Bearings
    Crankshaft Left = 6305/C3
    Crankshaft Right = 6305/C3
    Camshaft = 6001-Z
    Camshaft = 6906 /C3
    Transmission =6002
    Transmission =6202
    Transmission =6004
    Transmission =6204
    Front Wheel Left =6300-Z/MT
    Front Wheel Right =6300-Z/MT
    Rear Wheel Left =6301-RS1/MT
    Rear Wheel Right=6301-Z/MT
    Rear Sprocket Drum =6004-Z/C3
    Water Pump bearing =6000
    Clutch Plate pressure bearing = 6901
    Oil Seal
    kick starter oil seal = 16 x 26 x 5
    engine sprocket oil seal = 20 x 35 x 5
    waterpump oil seal = 10 x 31 x 13.5
    rear mags sprocket oil seal = 26 x 42 x 8
    front mags oil seal = 20 x 35 x 7
    credit to mr traxxas....
    boldstardex, unin, marquez704 and 3 others like this.
  3. kamen rider x
    kamen rider x Super Veteran
    Apr 22, 2009
    2,383
    325
    Klang
    Thank for the info MOD PHL.. ;););)
  4. phl6684
    Mar 29, 2008
    4,530
    464
    hehehe...
  5. kamen rider x
    Apr 22, 2009
    2,383
    325
    Klang
  6. Na0ki
    Na0ki Super Veteran
    Jul 16, 2009
    857
    56
    Selangor
    fuyoo.. klo masuk SPM kompom saya FAILED!.. :D
  7. kamen rider x
    Apr 22, 2009
    2,383
    325
    Klang
    Dulu dengan skrg SPM tak same..
    Hahahaha... :D
  8. WhiteT135lc
    WhiteT135lc New Member
    Nov 29, 2011
    25
    rawang
    salam... nak bertanya... sama ker bearing saize nie ngan lc es 5 speed tue....
  9. WhiteT135lc
    Nov 29, 2011
    25
    rawang
  10. phl6684
    Mar 29, 2008
    4,530
    464
    xpasti la bro white...
    da ade manual 5 speed??
  11. Wpt - Kcy
    Wpt - Kcy Veteran
    Jun 13, 2011
    268
    61
    143
    Sungai Petani, Kedah Darul Aman
    ada tak benda yang hang cari dekat HUB LEONG pekan lama mie?:D
  12. Seli
    Seli Super Veteran
    Oct 8, 2011
    47
    353
    Bandar Saujana Putra, Selangor, Malaysia
    Bro Mie-PHL...:rolleyes:
    Bole saya tahu jenama bearing2 yg disebutkan diatas...
  13. phl6684
    Mar 29, 2008
    4,530
    464
    bro seli
    jenama terpulang bro..nsk ada skf,fag,koyo, mcm2 ada...kod sama ja..
    bro adi
    selasa dia bg quotation harga skf n nsk...hehehehehe
  14. Seli
    Seli Super Veteran
    Oct 8, 2011
    47
    353
    :rolleyes:... oo yer ker...ok thanks Bro
  15. phl6684
    Mar 29, 2008
    4,530
    464
    no problem...
  16. WhiteT135lc
    Nov 29, 2011
    25
    rawang
    tak dapat lagi.... tengah dok cari la nie...
  17. Wpt - Kcy
    Wpt - Kcy Veteran
    Jun 13, 2011
    268
    61
    143
    hang ambik quotation SKF biasa atau high speed bearing atau SKF Enduro....abg tak pernah pakai lagi SKF nie. sbb masa mula-mula racing dulu depa ajar FAG atau IBC ja hahahahahahahahhaha:p
  18. WhiteT135lc
    Nov 29, 2011
    25
    rawang
    ada kat mudah.com bearing skf set untuk lc rm 180 jer... le caya ker....
  19. Wpt - Kcy
    Wpt - Kcy Veteran
    Jun 13, 2011
    268
    61
    143
    harga tu utk full set bearing atau crankshaft saje? kla utk 2 biji crankshaft bearing mmg harga tu (highspeed bearing), tp kla full set bahaya ooooo takut tipu je:D
  20. WhiteT135lc
    Nov 29, 2011
    25
    rawang
    nie link dia
    http://www.mudah.my/Set+Bearing+SKF+C3+untuk+Yamaha+135LC-12712023.htm
    Kami ade pakej menarik, pd harga yg sgt menarik. Fullset bearing C3 dlm enjin anda.
    Complete bearing dlm enjin,Crankshaft, gearbox, clutch, crankcase,dll = 6 Bijik
    HARGE Cuma RM180 sahaje untuk full set bearing enjin!(6 BIJI) Dijual secara pakej.
    Juga terdapat pakej ekonomi untuk crankshaft & gearbox sahaja. Sila call utk maklumat lanjut
    ha.... cam ner... dengar mmg best.... cer kita sembangkan
  21. Wpt - Kcy
    Wpt - Kcy Veteran
    Jun 13, 2011
    268
    61
    143
    yang dia bg biasa punya SKF steel bearing nie kla nak upgrade cari yang jenis SKF ENDURO C3 , kla yang racing SKF CERAMIC C4 bagi highrpm enjin a.k.a mereka yang tamakkan kuasa, nie contohnya
    SKF Enduro - The Racing Spirit
    SKF ENDURO known as bearing for racing, is used for high performance motorcycle, ensuring long service life in extreme conditions.
    There are two types based on application:
    1. Engine - Crankshaft
    2. Wheel
    [​IMG]
    [​IMG]
    1. Crankshaft bearing features:
    - Super hardened high quality bearing steel
    - Special heat treated for retainer
    - High-grade steel ball
    - High-precision internal radial clearance
    - Super finished raceway surface
    2. Wheel bearing features:
    - High quality bearing steel
    - Capping solution (metal and rubber) for maximum protection
    - Special grease
    Special Quality Through Innovation
    SKF Enduro special features give the following benefits:
    - Improve protection against contaminations as, for example,
    water, dust and rust
    - Increase bearing service life
    - Lower maintenance cost
    - Increased operating temperature
    tapi selama saya pakai bearing racing pernah FAG dgn IBC...but my vote goes to IBC saya pakai dekat crankshaft saja, saya pakai dr tahun 2009, cuma pada moto baru nie saya tak pasang lagi, buat rujukan:
    Buat tatapan Kawan2 semua tentang IBC Bearing::::
    http://www.ibc-waelzlager.com/
    http://www.spekuma.se/info/Super%20Precision%20Bearings.pdf
