rhoitol
what is your carb sir?i agree with you sir... i currently installed 57mm bore, rcdi, hardened valve spring, rcam, clutch spring, head and exhaust port. i dont feel big difference from stock set of my sniper mx.
why do you say so?its not as easy as you think sir
..hehe..youre kiddingi agree with you sir... i currently installed 57mm bore, rcdi, hardened valve spring, rcam, clutch spring, head and exhaust port. i dont feel big difference from stock set of my sniper mx.
because it's simply didn't worked for us and it's provenwhy do you say so?
the procedure is simple..let your tuner check your compression pressure and if its down,just shave some from your head or take off gasket etc..your mechanics knows it..if he doesnt know? better look for better mechanic..yeah what are the tweaks sir? and how much more budget will it costs knowing that vixion is already a costly one
What are your engine load sir?I need tips with vixion bore it only maxes out at 110 kph small tire xrm 125 can even beat my bike.
Vixion blockWhat are your engine load sir?
Cdi?Vixion block
yypang cams
28mm carb
high flow air filter
vixion valve spring
open pipe
90/80 100/80 F R
= 110 kph.
Is there any secret modification that needs to be done? pls pm me
sir @John Carlo is correct RCDIVixion block
yypang cams
28mm carb
vixion valve spring
open pipe
90/80 100/80 F R
= 110 kph.
BRT hyperband.Cdi?
sir, whats your sprocket combination?BRT hyperband.
Use lighten pin and piston, squishband make the vixion piston head as plat as posible if you can get a dome piston much better lighten magneto ang flywheel, pnp head, sprocket combi, clutch spring.BRT hyperband.
and read read read here... or ask some of our friendly t135 forumerFind a trusted and skilled mechanic sir
After 110kph is it full throttle what is the sound of the engin...Vixion block
yypang cams
BRT hyperband CDI
28mm carb
vixion valve spring
open pipe
90/80 100/80 F R
= 110 kph.
I used 80/80 front and 90/80 rear with disk assembly and i weigh 115kg. We have almost the same loads of engine but my sniper can run upto 130kph in normal driving position. Still its very weak compared to the mc's of our brothers here with the same loads.15x42 sprocket combi
Maybe my tires are heavy and im 74 kg.
Still would expect will top even at 130kph but cant.
Will try to have a tune up and see if it improves.
