Tuneboss Sniper Mx 150
Discussion in 'T150 & T135 General Topics' started by jariusxd, Jan 11, 2017.
  1. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    your problem is not on the fuel map, there is maybe a leak somewhere on head or intake manifold
    and when you change the throttlebody, you need also to adjust the TPS on tuneboss
  2. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    im using stock head and stock bore im satisfied with my set up for now but planning to put 62mm uma and uma superhead soon hehe i dont want to destroy my stock bore and head coz its sayang haha
  3. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    sir ur from ph also or other country?
  4. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    you need to change your injector and TB, better 34mm TB, our stock is 28mm
  5. gdeezzyy
    gdeezzyy New Member
    Jul 12, 2017
    13
    good evening, im new to this tuneboss ecu. im currently using 428h 14x45 sprocket set and high flow air filter(RAD). My problem is my current top speed decreased from 138kph(using stock ecu) to 133kph(tuneboss installed) my current map is table 44 i think(all standard bike setting from the tuneboss app) i plug read my spark plug and its running lean. need some help guys:(
  6. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    160cc injector and 32mm tb? planning to have one soon and change my air filter to high flow cone type hehe
  7. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    lean because ur using high flow filter try to back it to stock air filter coz the map ur using is all standard
  8. gdeezzyy
    gdeezzyy New Member
    Jul 12, 2017
    13
    i put the air box now, same result no progress. i cant find a pre tuned map in the tuneboss app that is similar to my bike's specs
  9. gdeezzyy
    gdeezzyy New Member
    Jul 12, 2017
    13
    i have also another problem after i install the tuneboss ecu, the thing is my fuel consumption is not working anymore( in km/L or 100kmL) it shows 99.9km/L always even if i reset the panel.
  10. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    are you using open pipe?
    gdeezzyy likes this.
  11. Wamonoseko
    Wamonoseko New Member
    Oct 29, 2016
    15
    Boss mxking035 anong lift ng cam ang pinakasakto sa stock head para hindi tutukod kahit walang pocket?
  12. gdeezzyy
    gdeezzyy New Member
    Jul 12, 2017
    13
    sir mxking currently using table 47 pala. sorry my bad. stock pipe sir, and back to stock air box with no air filter.
  13. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    CMS T2, strong
    Wamonoseko likes this.
  14. Wamonoseko
    Oct 29, 2016
    15
    Lift boss?5.7mm?5.8mm? Tas tamang clearance na dn boss,salamat
  15. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    5.8 lifet, 0.08in 0.08ex clearance
  16. Wamonoseko
    Oct 29, 2016
    15
    Cg boss,salamat.
  17. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    np
  18. Wamonoseko
    Oct 29, 2016
    15
    kumuha pala aq ng 57mm semi dome boss,ok lang kaya to?di kaya tutukod?may pocket sya
    Saka boss pala,sa cam may pinagkaiba ba to sa performance
    Cms t2 5.8mm
    At
    Specv 5.8mm
  19. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    cms t2 5.8 is safe, even for jvt fulldome 57mm,
    cms 5.8 and specv 5.8 is not same, different profile, I have not yet tried specv 5.8,
    I just tried CMS T2 and SpecV 6.5
  20. Wamonoseko
    Oct 29, 2016
    15
    Ah,,kala ko kasi boss basta parehas ng lift parehas dn ng performance
