Tuneboss Sniper Mx 150
Discussion in 'T150 & T135 General Topics' started by jariusxd, Jan 11, 2017.
  1. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    oh the table can be edited?
  2. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    yes you can with tuneboss manager pro, I edited map83 for you
  3. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    oh the pro version gonna try your edited map tom. sir hehe tnx for the effort! :thumbsup: im using the ordinary version of manager thats why im wondering how come you can edit downloadable maps hehe
  4. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    np
  5. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    sir tnx for the map i've noticed better response in throttle it is dyno tuned?
  6. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    no, I just estimated the fuel base on my experience on my old setup, I just made it the time i send it to you, actually i never edited any map during may old setup, using cms t2 and open pipe.
  7. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    ahhhh so what is your new set up now?
  8. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    tuneboss
    62mm semi-dome lightened piston
    32mm Throttle Body
    12holes Injector
    22/20 bigvalve with headworks
    6.5 specV camshaft
    Uma Valve Spring
    Adjustable Timing Gear
    Manual tensioner
    Faito Coil (before is coil from multicab for 1yr+)
    Faito Crankshaft Bearing
    Denso Iridium (I have 3 different sparkplug, depends on purpose)
  9. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    nice set 180cc?
  10. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    yes or 177cc
  11. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    nice
  12. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    if you plan to use 62mm+cms t2, it is not advisable for me, it will have over compression or need 10/12 holes injector to deal with overheat
    in my experience,
    62mm + cms t2 + stock injector + w/0 airfilter - hard to tune, overheat easier if not well tuned, 14/42 or higher
    62mm + cms t2 + 12 injector - cold engine, better with mx135 sparkplug to deal with overgas and better than 1st, 14/42 or higher
    62mm + cms t2 + 12 injector + 32mm TB - easier to tune, can use any sparkplug to tune, better with stock SP, 15/42 or 15/43
    62mm + cms t2 + 12 injector + 32mm TB+ 20/22 head - better with shaved block 1.2mm no base gasket, stock SP, 15/42 or 15/43
    62mm + specV 6.5 + 12 injector + 32mm TB + 20/22 head + timing gear + simota - I like it, very easy to tune, easy e-start, 15/42 or 15/43
    its better to use racing coil like multicab coil or Faito FI coil
  13. Sam6244
    Sam6244 New Member
    Jun 12, 2017
    11
    Hi bro do u know swr ttb how to adjust?
  14. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    i'm using SWR also, 32mm
    Firts after install, calibrate Tuneboss AFR (very important), it is not calibrated and will not go at 100% throttle
    Second, you can adjust the idle, see the yellow plastic screw, you can hear the rpm changing while adjusting (set to 1.3-1.5k rpm)
    Third, need to tune again in tuneboss (add some fuel)
  15. Sam6244
    Sam6244 New Member
    Jun 12, 2017
    11
    Any results for add fuel tq bro
  16. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    what do you mean? power results? or map settings?
    what is your setup?
  17. Sam6244
    Sam6244 New Member
    Jun 12, 2017
    11
    Rpm high low adjust ttb and add fuel
  18. GUKIMEN
    GUKIMEN New Member
    Apr 11, 2016
    26
    nice suggestion sir but i'll go for super stock set up for touring use i'm not more on racing hehe
  19. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    you can add 57mm dome piston, simota airfilter, 32mm throttle body, faito coil, hyperclutch, headworks
  20. Sam6244
    Sam6244 New Member
    Jun 12, 2017
    11
    Hi bro dyno tuning good or not?
    I just find out a shop near at my location
    The fuel high low problem still same if dyno tuning is the best way i think i going
