Thermostat Removed..
Discussion in 'T150 & T135 General Topics' started by juan pusok, Dec 26, 2014.
  1. juan pusok
    juan pusok New Member
    Oct 8, 2012
    44
    11
    manila
    have anyone tried to remove the thermostat on your t1355?pros and cons?
  3. pepito16
    pepito16 Member
    Aug 13, 2014
    159
    38
    43
    candon city, ilocso sur
    tinangal ko na sa akin paps ok aman,, ang prob lng pag wala un is matagal uminit,, ang kinagandahan is tuloy tuloy rotaqtion ng coolant nd ung dati ung nasa head and block lng sia
  4. MickO_HCMC
    MickO_HCMC New Member
    Feb 7, 2013
    70
    34
    18
    Saigon
    Vietnam
    I removed thermostat 1 year ago no problem, I live in Vietnam so temperature never colder than 20 deg C, bike takes a little longer to warm up, so if you live in a very cold climate thermostat is important.
    Current spec of bike below:
    Yamaha Exciter (T135 in Vietnam) 183cc
    UMA Racing super-head (sport) 23mm inlet/20mm exhaust
    AIS removed (blocked off with plate)
    UMA Racing cam
    63mm Ø Malossi bore kit
    Stroke 58.7mm (Standard)
    Sprint Filter Conical Pod style air filter (water proof)
    Exhaust; Leo Vince (Corsa Carbon)
    33mm PWK carb (PJ=38 MJ=120)
    LHK petrol filter
    Malossi Electric coolant pump
    Racing coil and lead
    UMA Racing / IMC RCDI (4 maps, rev limiter, timing advance / retard 9°)
    Brisk Racing spark plug AR10ZS
    Shorai Lithium Ion battery
    Oil cooler (KTL Tecnic)
    Stainless steel oil filter (FLO)
    Racing clutch 6 springs
    Transmission Standard 5 speed
    15F/41R sprockets (Hoddaka)
    Chain (428 VX DID)
    Standard front forks (Black from GP)
    300mm front disk (RB) with standard caliper
    Standard swing arm
    RPM rear mono shock (spring preload + rebound adjust)
    Std. rear disk and caliper
    Tires F; 70/90 R; 110/70 Michelin Pilot Street
  5. superturbocompound
    superturbocompound New Member
    Jan 8, 2009
    42
    11
    north of borneo
    don't ever remove your thermostat....the engine life will go down hill really fast
  6. blackknightrealms
    blackknightrealms Super Veteran
    Jul 5, 2011
    869
    96
    Rodriguez, Rizal
    Others
    If your engine are loaded.thats most likely the way to do that.unlesd you are in the country who has ambient temperature of 25 degrees down all day.you will likely need those.for stock engine.reaching ideal operating engine temperature will surely will take time.
    juan pusok and jangbest like this.
  7. jerry loyola
    jerry loyola New Member
    Oct 29, 2016
    kidapawan city
    Goodpm masters,just want to hear your advice...my mechanic removed my bike's thermostat bcoz he said im already on a 62mm block my problem now is after about 50km travel when i check my coolant in d radiator its in low level and it seems some of d coolant went to d reservoir bcoz its already above full level..is this normal or not?plz help!!!
  8. Mohd Asraf
    Mohd Asraf New Member
    Nov 22, 2016
    What is pro and cons for termostats removal?
