T135 Sprocket Gear Specs with Real speed
Discussion in 'T150 & T135 General Topics' started by traxxas-modifier, Apr 28, 2008.
  1. raprap
    raprap New Member
    Oct 22, 2015
    roxas
    guys..​
  2. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    Mga master, mga ilan po actual speed nito sa smx135
    Reading: 158kph (600m+)
    Tire: 90/80-17 stock mags
    Gearing: 1st, 2nd & 5th gear(26/26)
    Sprocket: 38/16
    Ano bet nyo sprocket sa 400m drag stock mags? Touring set lang po motor namin
    Lightened Magneto
    Lightened Flywheel
    Counterweight balanced crankshaft
    1,2,5 racing gear
    Fag C3 Crankshaft Bearing
    19/22 oem head port & polish
    CMS Cam T2
    JVT 62mm tabas 2mm (3 base gasket)
    Faito 7600 coil & koso plug cap
    Arata CDI adjustable
  3. gdeezzyy
    gdeezzyy New Member
    Jul 12, 2017
    13
    if i change the rear sprocket of my sniper 150, from 42t to 45t, will it change the accuracy of speedo display? thanks
  4. Jai_Scb
    Jai_Scb New Member
    Sep 6, 2017
    Hi guys..im newbies and juz need your opinions. Below are my bike spec.
    Type : Yamaha LC 135 ES 5speed (2014) Malaysia
    Block : 63mm
    Head : 19/22
    Cam: Cms
    s.v: Cms
    CDI: Orange Thai Cdi
    Carb: Tzm Mikuni
    Gearbox: 2,3,5 racing gear
    Con Rod: Ikk Racing Rod
    Bearing: Fullset Bearing Enduro
    Ekzos: Standard v2 5s operate for spec 63mm.
    Tayar: 80/90 Front - 80/90 Rear
    Owner Weight: 85kg
    Sproket: 14-30 428 - Over rev - Gear 5
    15-30 428 - No top speed
    15-32 428 - Over rev - Gear 5
    any suggestion for sproket..?and anyone use same spec as mine..??
  5. docgabby
    docgabby Super Veteran
    Jun 11, 2007
    949
    459
    legaspi city
    what is racing gear 2,3,5?? what are their ratio or teeth?
    jangbest likes this.
  6. levie dela cruz
    levie dela cruz New Member
    Sep 15, 2017
    hermosa, bataan
    Try my monster combination of my kawasaki barako 16/34 sprocket, apido racing cdi, apido racing open pipe, 32mm carb, clutch spring, port & polish...
    16 rimset, low profile tire... wotwooooow
  7. Jai_Scb
    Jai_Scb New Member
    Sep 6, 2017
    sorry..it was 1st, 2nd and 5th gear
    1st - 32t / 2nd - 29t / 5th - 26t
  8. levie dela cruz
    Sep 15, 2017
    hermosa, bataan
    Good day all my friends here i need any advice for my kawasaki barako 2...
    i want it more stronger and much faster ...
  9. docgabby
    Jun 11, 2007
    949
    459
    legaspi city
    this is not a kawasaki barako forum
