Sniper 150 General Thread
Discussion in 'T150 & T135 General Topics' started by CLutch, Nov 10, 2015.
  1. JapSpeed
    JapSpeed Super Veteran
    Dec 23, 2013
    2,029
    946
    Bacolod City
    it's a risky modification... i'm not sure if it works.
  2. snipermxmalayaklan
    snipermxmalayaklan Super Veteran
    Oct 4, 2013
    419
    341
    Aklan
    i think it's only possible if you got complete tools since cam part needs precision works i think and not just some noob welding, modifying etc. it will work but i think i wont last long.
    JapSpeed likes this.
  3. eldridge27
    eldridge27 New Member
    Jul 11, 2016
    20
    not holes in camshaft itself.. but in camgear.. if you see theres a 2 holes in camgear..in top and in bottom of Bolt.. what if i widen the holes so i can move the camshaft like uma adjustable camgear.. i will make the stock camgear Adjustable by widening those 2 holes.. i hope you can imagine my point
  4. snipermxmalayaklan
    Oct 4, 2013
    419
    341
    Aklan
    yeah, thats possible. that DIY thing. just be making sure it's tight enough to stay in place or weld/cover the excess hole.
  5. eldridge27
    Jul 11, 2016
    20
    so risky,, i regret that i shave my block.. i didnt realize that the timing would be retard,,,, is it better if i put the timing in advance? instead of delay ,, because delay timing makes my MC not idling
  6. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    that's possible, but you need to measure it carefully else you might end up unstable engine, vibration.
    snipermxmalayaklan likes this.
  7. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    for me better delay, good for long rides and everyday rides, good for top speed. i did that on my mx king:thumbsup:
  8. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    if you don't have good idle, try to adjust the throttle body air screw, or the idle screw.. tried that after changing racing cam and low idling occurs.
  9. snipermxmalayaklan
    Oct 4, 2013
    419
    341
    Aklan
    don't regret Sir. just buy a bottom gasket and make it 2.
  10. eldridge27
    Jul 11, 2016
    20
    @japseed ,, where is throttle body air screw located? bcoz i tried to adjust the idling screw but still not working
    @snipermxmalayaklan,,, sir will it affect or lower the compression if i add 1 more head gasket?
  11. snipermxmalayaklan
    Oct 4, 2013
    419
    341
    Aklan
    yes it will make the compression lower. just like mine, i put 2 bottom gasket last two weeks to lower the compression in order for me to be able to use the stock pipe since it is now restricted to use aftermarket pipe here in our municipality. the drawback as well it is it will lower your speed and top.
  12. snipermxmalayaklan
    Oct 4, 2013
    419
    341
    Aklan
    if you centered that timing with the use of two gasket but you want it in highcomp, you could buy a blank piston and machined to a good person to meet the specified compression you just wanted..
  13. Storm_rider
    Storm_rider Super Veteran
    Jul 22, 2010
    1,324
    308
    Imus, Cavite
    Planning to buy t150, other than the knocking sound on the clutch housing, is there any more problems you guys encounter? Like moisture on the speedometer or anything else?
  14. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    so far sir sa clutch housing lng issue.. the rest wala na..
  15. julianito_maldito
    julianito_maldito New Member
    Jan 7, 2012
    31
    12
    tagum city
    those who are claiming na sirain ang king yun yung mga taong walang king..hahhahah
  16. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    that's right...:thumbsup::thumbsup:
  17. Boss ej
    Boss ej New Member
    May 3, 2016
    38
    19
    hi guys this is me again needing your expert opinion with my vice lol.. Does anybody here has asio mags fittd in their babies? Based on what seller says, rim sizes are 2.5 frt and 3.5 rear. And daytona mags 2.75 frt and 3.5 rear. Does it fit or do i have to change frnt fender fork and swingarm to,make it fit? Thanks bros. u guys are geniuses thats why always want to,hear ur opinions. First
  18. sparky150
    sparky150 New Member
    Aug 3, 2016
    try to use, extra base gasket sir
  19. JapSpeed
    Dec 23, 2013
    2,029
    946
    Bacolod City
    good idea but it will lessen the compression.. sayang lng yng rephase nya...
    or maybe adding 1 base gasket and semi dome piston.
    sparky150 likes this.
  20. Storm_rider
    Jul 22, 2010
    1,324
    308
    Imus, Cavite
    Maybe not, he just sold his t150 days ago due to some issues he encountered, and did you guys tried to ride your t150 on rainy days?
