Masalah Air Coolant Masuk Enjin, Valve Dan Piston Berlanggar
Discussion in 'MALAYSIA: LC150 / 135LC owners' started by Jeff Zain, Dec 18, 2012.
  1. Jeff Zain
    Jeff Zain New Member
    Dec 30, 2011
    91
    20
    Kuching
    nk mintak pendapat otai2 sekalian..........
    cerita dia gini...
    LC aku dulu ada mslh semput n stelah lama brcari sebab musabab dia, rupa2nya valve bengkok...
    tukar valve n mslh semput pun hilang tapi belom ok sepenuhnya sebab LC aku memang ada mslh lain gak sperti connecting rode...
    pendek crita... slepas tukar valve baru.. timbul pulak mslh baru iaitu
    1.piston dan valve brlanggar dan trpaksa setting lari 1 mata, baru ok(pelik kan?)
    2.coolant masuk dlm enjin
    - tukar cyclender head (seken), tetap gak valve n piston brlanggar n kena setting lari 1mata baru ok
    - slepas tukar head, gasket baru trmasuklah wtrpump cek skali, air coolant tetap masuk enjin....
    note:
    head seken ni dh modi, korek intake n outake n skimming..... (ikut seting cun, piston brlanggar dgn valve n trpaksa seting lari 1 mata baru ok)
    head lama ori (ikut seting cun, piston brlanggar valve n trpaksa seting lari 1 mata baru ok)
    blh tak otai2 semua bantu saya dlm mslh di atas...
    terima kasih.................
    botakk likes this.
  3. skyrocket
    skyrocket Super Veteran
    Sep 8, 2011
    651
    82
    pkai cam rcing ke?
  4. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    Cam or bro
  5. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    ORI camshaft bro
  6. skyrocket
    Sep 8, 2011
    651
    82
    aih pelik je..cam std pn knocking jgk?marking ok?xkn magnet lari pulak..
  7. hamdanz
    hamdanz New Member
    Nov 22, 2012
    57
    14
    Petaling Jaya, Malaysia
    rantai dah kendur kot..
  8. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    kalo ikut marking, kompom knocking.... so, kena 1mata, baru ok...
    mngkin head n blok tu dh kena modi oleh owner lama huhu..........
    sebab tu skarang ni air coolant masuk enjin.....
    so, ambik senang, tukar blok n head baru pastu overhaul enjin ganti bearing yg slack oleh air....
    nk anta bengkel besok........
    nanti aku update lagi slepas overhaul cane
  9. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    rantai apa yg kendur? timing chain ker?
  10. hamdanz
    hamdanz New Member
    Nov 22, 2012
    57
    14
    timing la tu kot...dah lama ker ?
  11. adam_john99
    adam_john99 Super Veteran
    May 5, 2010
    1,018
    212
    KL
    bro jeff zain, head ko yang tukar tue bengkok rasenyer kot....cer ko tgk betul2, slalunyer head yang dah bengkok je memungkinkan air masuk dlm enjin....slalunyer sbb overheat...maybe gasket dah takleh tahan panas and overheat...tue yang head bengkok and air coolant masuk...
    satu hal lagi, aku rase sbb ko kene alih marking tue sbb rod ko dah goyangkan???sbb la tak leh set kat marking ori...ko alih marking advance or retard???maksud aku ko alih marking satu mata ikot arah jam or lawan jam???cian gak ko nie...byk problem kene....
    just my 1 cent bro...
  12. pomen
    pomen New Member
    Oct 2, 2012
    selangor
    Aq pn dlu pnh kne mcm tu. Air coolant asik msuk dlm enjin & Connecting rod bunyi. Tu la aq gatal sgt nk modi moto aq tu. Nk cbe pnye psl.hehe..So aq tukar head baru n gasket top overhaul baru ok ( tkr kat rumah). Harga head tu aq da lpe bp RM. Head lame da rosak. Connecting rod aq tukar kat kedai.Aq cabut enjin seketul anto kedai. So just bayar connecting rod 1 set ,bearing,gasket enjin kiri n kanan n upah je(dlm RM300). So jimat sket. Klu boleh tkr je trus timing chain tu. mungkin da rosak. Harap info ni blh membantu. TQ
    kojack and adam_john99 like this.
  13. cr0wer
    cr0wer New Member
    Sep 4, 2012
    67
    33
    21
    Kuala Lumpur
    larikan je 1 mata...
  14. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    bro Adam, dgn head asal, air masuk n tukar head pun msh leaking gak........
    skarang ni moto msh kat bengkel n mekanik tgh cuba blok lain(baru) plak dgn head baru(beli seken).. kalo dgn blok baru ni x da lagi leaking... so akan diteruskan dgn fasa overhol plak utk ganti bearing2 dlm enjin, jack blk con rod(rod tukar baru) n maybe timing chain pun ganti baru trmasuklah gear assy...
    so harap2 dgn blok baru nanti selesaikan masalah leaking tu so baru dapat nk overhol n setting cun2...
    terimakasih atas pendapat kalian semua......
  15. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    adam_john99 likes this.
  16. adam_john99
    May 5, 2010
    1,018
    212
    KL
    Pape pun moto dah kat kedai...so biar la kedai solve dulu.then update je kat sini k bro....slamat maju jaya
  17. pomen
    pomen New Member
    Oct 2, 2012
    selangor
    Semoga berjaya bro..insyallah..
  18. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    TQ bro Adam n Pomen....
    Siap jer LC aku nanti, aku update kat sini erk....
  19. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    masalah bocor dikenalpasti melalui waterpump seal n bearing yg dh haus....
    ganti baru 2 benda tu dan Alhamdulillah setel lah mslh air coolant masuk enjin..........
    now diteruskan dgn proses overhol enjin utk ganti bearing2 dlm enjin yg dh slack oleh air coolant, ganti seal, ganti rod, timing chain n siap sumbat blok baru 59mm brand yamaha (thailand mari).. jetting carb pun tukar sebab blok dh besar n head plak dah kena korek....
    tapi camshaft plak msh ori haha....
    aku pun x kisah sangat lc aku x super laju, cukuplah sekadar ringan n syok sendiri hahaha...........
    performance??? nanti selepas running in aku update balik....
    kojack, adam_john99 and Pandir135 like this.
  20. hamdanz
    hamdanz New Member
    Nov 22, 2012
    57
    14
    berapa kos tu...?
  21. Jeff Zain
    Dec 30, 2011
    91
    20
    Kuching
    gaji jer rm250.....
    parts bearing dlm enjin 6biji, bearing wtrpump 1biji, timing chain, oil seal, jack blk n ganti rod, seal wtrpump 1, head seken 1, blok yamaha thailand 59mm 1, gasket, coolant, eo n jetting.....
    semuanya rm600...
    n jumlah kesluruhan dia rm850.00..................................
    itulah harga yg perlu aku bayar utk kesihatan LC aku......
    apa2 pun, biar abis duit, janji LC sihat n utk buat cari rezki tu.................
