Tr3C3
Revised Penal Code Article 69 – Penalty to be imposed when the crime committed is not wholly excusable. A penalty lower by one or two degrees than that prescribed by law shall be imposed if the deed is not wholly excusable by reason of the lack of some of the conditions required to justify the same or to exempt from criminal liability in the several cases mentioned in Article 11 and 12, provided that the majority of such conditions be present. The courts shall impose the penalty in the period which may be deemed proper, in view of the number and nature of the conditions of exemption present or lacking.
Naku naku nahilo na ang bagong lasing.. dapat uminom para magising hahaha Hindi ko maarok, NOSEBLEED ako Fiscal hahaha
So ibig sabihin pala if sniping_area has YELLOW RIBBON tag or in any instance of Temporary Insanity in which if, and only if, the behavior is proven by a licensed psychiatrist can be acquitted to such act? (Which in this case, they are inside the property of sniping_area.. or would it even apply in a neutral ground?)
