Koso Digital Problems In My Sniper 135
Discussion in 'T150 & T135 General Topics' started by MightyThor, Jun 24, 2016.
  1. MightyThor
    MightyThor New Member
    Jun 24, 2016
    patulong naman mga sir. yung koso digital ko kasi sa sniper classic madalas nag rereset and nag blink naman minsan tapos yung needle tagal bumalik humihinto sa dulo then matagal bago bumaba.
  3. MightyThor
    Jun 24, 2016
    Problema nalang mga sir is yung pag switch on mo yung needle tagal bago bumaba or bumalik,
    mhon_578 likes this.
  4. mhon_578
    mhon_578 New Member
    Aug 17, 2013
    69
    27
    21
    bacolod city
    Red wire connection direct battery not in ignation switch
    Gie likes this.
  5. julius b. flaviano
    julius b. flaviano New Member
    May 30, 2012
    86
    29
    21
    bacolod city,negros occidental
    re check your wiring system maybe you forgot something or manual of koso
    JapSpeed likes this.
  6. sniper135lc
    sniper135lc Super Veteran
    Oct 9, 2007
    1,017
    136
    laguna philippines
    from where you live bro?
    i think you have a wrong tapping of wire for the supply.
  7. Gie
    Gie Super Veteran
    Sep 19, 2011
    1,340
    681
    Quezon City and Malabon City
    yung red wire sir dapat naka direct po sa ignition switch socket papuntang battery for (standby power) para sa clock para di narereset.. magiging normal din po ang galaw ng needle nung taco mo kapag naayos mo na yung wiring.. hope it helps..
  8. sniper135lc
    Oct 9, 2007
    1,017
    136
    laguna philippines
    i think koso has a plug and play socket for the ignition switch. you have to attached it on the stock socket of the ignition. and i believe the main socket has already for the clock which is the power will not be interrupted when you turn off the switch since you already attached the adaptor system on the ignition switch. kindly check the manual of koso there was some two wrong wiring in there which is the turn signal light and the rpm wiring need to be swapped.
  9. weng82
    weng82 New Member
    May 31, 2016
    12
    General Santos City
    where to buy koso dig.speedo?
