macoolet
i'm not an expert hahaha,you're close to traxxas and chiglai's place,also method21,you can go directly to their placeHehe that means my theory is right just need to confirmed it with the masters.
ok i already purchased a rubber gasket maker (Three Bond) thanks for the info bro.No problem,just make use of a better tri-bond sealant and avoid to cover up the passages..good luck
yep definitely a must especially if you're going to use a racing cams...Kenshi du u do pocket valve on ur piston after removing the base gasket?
no idea on s4evo.If i remove the base gasket on vixion block is it necessary to pocket valve the piston?im using s4 evo cams from faito..stage 1 lift..any advice on the setup???thanx in advance..
what do you mean?Hi guys, c
Help me to compare btween nouvo lx135 pis (oval head) and remove bottom gasket (0.5mm)
In vietnam, scooter yamaha nouvo lx135 has same bore & piston 57mm. So, to increase cr we can change that piston (higher than stock t135). I don't know is it same as remove bottom gasket (0.5mm)?what do you mean?
Thanks paps ...@ pres jangbest. i think doc gelo of odie perry doing this squishband. ask for it thru pres odie. im planning to do this to my bike with 57mm. but dunno how mm will be shave to my block...
