Help Pls Sir..newbie..
Discussion in 'T150 & T135 General Topics' started by tol, Jul 18, 2015.
  1. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    just installed pitzbike rcdi and hispeed valvesprings..what should be my next move..??need help sir..thanks..
    :help:
  3. JapSpeed
    JapSpeed Super Veteran
    Dec 23, 2013
    2,029
    946
    Bacolod City
    racing camshaft.. :thumbsup:
  4. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    thanks sir Japspeed..what brand exactly sir..??:oops:,would it be ok on my stock engine sir..??TIA..
  5. sixty-thirty
    sixty-thirty Veteran
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Vixion ? Uma ? Cms ? I think all of them are good :D
  6. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    Thanks sir sixty..its a big help..
  7. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    Could it cause a problem on my stoxk engine..?^^
  8. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Are you planing to use the stock bore kit ? Depends on the lift of the cam some are plug and play others you need to poket in the piston a bit .
    tol likes this.
  9. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    Yes sireeee..im planing to stay on my stock bore..just wana buy some partz that could improve my snipeeeee's speed and perfamnce..
  10. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    What do you have in mind ?
  11. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    i would stay on my stock bore..and have some twirks on my engine sir..i just want to install partz/mods that wont effect my stock bore sir..for ex cams..cdi..cams..etc..hehehe,can you help me sir..
  12. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Open exaust
    cdi
    valve spring
    gear set
    sprokect combination
    those are the thing you can change in my experience
  13. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    I just instaled pitzbike rcdi..hispeed vs,working on my pipe sir..my current sprocket set is 14/40..i havent tested my top yet..
  14. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Means your bike is better then mine hahhaha ! I'm stock jupiter mx 4speed... I have a 60mm faito kit ,cms valve spring, cms gears 1-2-4. . Faito 7400 ignition coil inside my room still in packing next month I will install everything .. 166cc .. only thing I change currently is my tire 100/70 and sprokect to 14/39
  15. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Upgrading the displacement is the best way to get max power.. a uma 62mm block with a sweet long crank will give you crazy . I had the same idea as you but I tested a friend's 63mm classic .. it's crazy fast .. that's when I decided that I must upgrade my bore to keep up with them ... 60mm for fuel economy reasons .
  16. tol
    tol New Member
    Jul 17, 2015
    32
    cotabato city
    lol..damn!166cc..!cool..ill be trying stock bore first sir..as u know im a newbie..still on y experementing stage..:rolleyes:..i think ill go with camshafts,racing cams,racing coils etc..:)
  17. sixty-thirty
    May 21, 2015
    352
    90
    156
    male'
    Maldives
    Do your research bro, this site has ever thing very detailed but the thing is I only understand English makes it hard ..
  18. Carlomx150i
    Carlomx150i New Member
    Feb 15, 2017
    Sir japspeed can you teach me on how cams works.. Like power band, cam lift, etc etc.. Im planning to upgrade kasi ang cams from stock to cms 5.8 cams for mxking 150... Thank you sir.. And other forumers for their suggestions and knowledge..
  19. The-flash
    The-flash New Member
    Jan 24, 2016
    5
    Others
    does anyone knws aout uma cam details? lift?
