Hard Shifting Stock Sniper Mx?
Discussion in 'T150 & T135 General Topics' started by projectdimpreza, Aug 16, 2012.
  1. projectdimpreza
    projectdimpreza Veteran
    Apr 6, 2012
    263
    13
    136
    Pasig
    newbie question here. im having a problem shifting gears on my sniper MX because its hard and steep.. im also a owner of sniper classic but i never experience hard shifting on classic. is there anyway to fix this problem?
  3. Adrian Relato
    Adrian Relato New Member
    Aug 15, 2011
    55
    11
    Rizal
    bro mx owner here...did you already change your oil? i experienced that too i just change my oil..prob fixed..based on my observation and experience, yamalube is only good up to 700 km if you reached that shifting gears change dramatically contrary to what 3smechanic recommends.
    unless theres a serious prob.
  4. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    my gauge reading is 7K+ and i do change oil often. at yzone.. but they only use yamalube on my MC. any oil recommendation?
  5. HKholic
    HKholic Member
    Oct 14, 2011
    192
    157
    58
    Buôn Ma Thuột, Dắk Lắk
    Vietnam
    At 7k on the odo, maybe time for some semi-synthetic or full synthetic. Will help to smooth things out.
    snipermxmalayaklan likes this.
  6. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    what is semi and full synthetic oil? sorry newbie question.. what oil do you recommend for my sniper MX?? also what type of oil is yamalube? thanks for the reply!
  7. jcm1130
    jcm1130 Super Veteran
    Mar 5, 2012
    2,127
    2,635
    San Simon, Pampanga
    i still use yamahalube.. its like a mineral base oil..
    do not use synthetic oil, it will shorten the lifespan of your clutch lining.. IMO
    because the oil used by the engine and the clutch system is merely similar..
  8. Adrian Relato
    Aug 15, 2011
    55
    11
    Rizal
    projectdimpreza
    fully synthetic oil might cause prob in clutch lining depending on the brand of oil. Check with the label, repsol fully synthetic 10w 50 and 20w 50 is specially designed for wet clutches and also mobil 1 fully synthetic. so far i dont experience any prob with repsol. i havent tried mobil 1 because its expensive. i would advice you go have it check at yzone for you to make sure.
  9. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    do u experience shifting from 2nd gear to 1st gear but it shifts in neutral ? im sure i fully hold the clutch when shifting... but most of the time when im in low speed it shifts in neutral instead of 1st gear.. by the way i have no problem shifting from neutral to 5th gear on high speeds.. problem comes in low speed.
  10. Adrian Relato
    Aug 15, 2011
    55
    11
    Rizal
    no hard shifting from 2nd to 1st gear. sometimes bro its a matter of timing. what i experienced though is when im in 5th gear and i suddenly stop, and i need to go back to low gears i still have to move the bike forward a bit for it to kick in. i guess its normal in manual transmission but if you feel like theres a serious prob go to yzone have it check.
  11. Adrian Relato
    Aug 15, 2011
    55
    11
    Rizal
    sometimes bro its really hard to diagnose if theres a prob. if you have a friend who also have mx try to compare. but you check what oil he's using., from that you can have your baseline. just an idea
    xniper03 likes this.
  12. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    i experience this since i got the bike 7 months ago.. maybe its not as smooth in shifting unlike the sniper classic 4 speed.
  13. Adrian Relato
    Aug 15, 2011
    55
    11
    Rizal
    i dont experience that on my bike bro only when its time for me to change oil but shifting is not that hard. I think you need to have that checked so you can avoid further damages and expensive maintenance cost it the future.
  14. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    guess i need to try another MX to see the difference.
  15. Paladin
    Paladin Super Veteran
    Aug 28, 2011
    1,455
    447
    Quezon City
    Bro, try to adjust your clutch deeper. Gears will not switch properly if your clutch is shallow. No problem with yamalube since you are make change oil regularly.
  16. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    how do i adjust the clutch? i remember adjusting the two nuts in the clutch cable is that what your pointing to ?
  17. jefplacido
    jefplacido Super Veteran
    Sep 12, 2010
    2,399
    383
    Valenzuela-Makati
    by removing the front panel cover (the headlight with front panel fairings)
    then you will see the adjuster on the clutch lever imo,not the two nuts below your clutch cable located at the crankcase,but it is interchangeable
  18. turbulence
    turbulence Super Veteran
    Sep 17, 2010
    767
    49
    Manila
    adjust your clutch
  19. Paladin
    Aug 28, 2011
    1,455
    447
    Quezon City
    The easiest way is to adjust clutch height clearance above the crank case or if you use racing boy lever, you can adjust adjust it there.
  20. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    im using sniper MX is that the same with sniper classic? if i remove the front fairings is clutch adjuster u saying is the same location in MX and classic?
  21. projectdimpreza
    Apr 6, 2012
    263
    13
    136
    Pasig
    In my experience shifting goes smooth when im running on high speed.. example 30- 40 kph.. but when im below 20 kph or in idle... shifting is hard, gear hits something before its shifts.
