Fuze Repeatedly Busted/replace (what Could Be The Problem)
M man_sate Super Veteran May 23, 2017 #2 Use 10A fuse or check cable connection at magnet coil. Maybe it loose. Check your rectifire. Check your voltage level to make sure it not overvoltage. You can check with manual voltage required or change your rectifire with your friend to verify it.
weng82 New Member May 25, 2017 #3 Thanks man a big help i rewire it and check its connection there is a grounded part fix it already
M man_sate Super Veteran May 29, 2017 #4 weng82 said: Thanks man a big help i rewire it and check its connection there is a grounded part fix it already Click to expand... Good you figure it by yourself.
