Engine oil. . .
Discussion in 'T150 & T135 General Topics' started by Snippy, Dec 21, 2008.
  1. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    It's not the brand. It's the model of the oil. As long as you buy the top of the line model(synthetic) it will give you better protection than the cheaper models. It has additives that will protect your engine, lower temperature and better mileage.
  2. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    It's like gasoline, more expensive and higher ron is always better.
  3. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    My spec is 62mm semidome lightened, SpecV 6.5/cms 5.8, 32mm TB, 12holes injector, 20-22 head ported, hypeclutch, faito bearing, faito coil, iridium sp, Tuneboss and 22,000+ mileage
    that is why I can see the difference of the oil I used.
    I made more than 30maps to tune it smoothly by long drive (400km+ each ride) and using different sparklugs, I can feel my engine man.
  4. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    Better oil is always better regardless of what engine you put it in. There is no engine oil for specific engine modification. If performance difference is very noticeable, then why are there still a lot of brands available? Why do companies have several models with different prices? It's the additives they put on their product that increases the price. And these additives improve the quality of the oil.
  5. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    yes you are right,
    yamalube new = 245
    Power 1 = 260
    Shell Advance = 300/350(not sure, i forgot)
    Motul 3000 = 400
    thats why maybe the last oil i used satisfed me, and have no plan to buy more than 500pesos oil, cuz im changing every 1000km
  6. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    Btw, why did you not use full dome? It will give you higher compression and more power. Who ported your head? Porting without proper knowledge will lead to poor performance. Porting is not as simple as making the head shiny or bigger.
  7. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    it is for daily used, Mikki Torres do the convertion and headworks and lightened the piston
    only exhaust is shiny, the intake is I dont know what it's called, but like hairlines scratch
  8. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    That's correct, intake should be rough. Exhaust can be shiny. If for daily use, why the modifications? It's harder to start and less fuel efficiency. Better have two bikes. One for daily use and one for racing. Modified bikes will not last very long. They are built for speed and very expensive to maintain.
  9. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    I don't have kick starter since after 10days of my bike was purchased, Now I'm using SpecV Cam 6.5 without decompression pin, one click only for electric starter, no issue
    I installed tuneboss and cms cam after 1month+ and after 5 months I installed 62m
  10. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    only issue is the first time I installed 12holes injector, hard to start and rough run until I tuned it well. And also hard start becuz of pipe, only I discovered that pipe with to much carbon will make it realy hard to start for modified engine
  11. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    Very good read.
    1. Stock spring valve is touted to support till at least 11k RPM before the valve will float.
    Aftermarket racing spring valve is recommended, but, read the last paragraph.
    2. For daily usage, not for racing use, using a camshaft with a less aggressive cam profile is recommended, for example, stock cam. The thing with camshaft is, if you change it, you gain somewhere, and lose somewhere, unless your machine is of a very big cc with torque everywhere. Example, for stock T150 camshaft, peak torque will occur at 7k RPM while peak power will come out at 8.5k RPM. If you use racing camshaft, you may gain a bigger power gain, but it is shifted into a higher rpm zone, usually at around 10k RPM.
    Meaning, you will need to rev your bike more to get into the power-band. For racing? No problem, for daily use? You decide if you love to rev.
    3. Very subjective, I myself use our home-bred ECU called Tuneboss, very feature packed, with wireless Bluetooth connection for dashboard monitoring and tuning. You can tune with your own Android tablet, using Tuneboss Manager Pro, downloadable for free from Google Play. But as usual, for best result, you should send you machine to a professional tuner to get the best AFR(air-fuel ratio) and ignition timing setting for every throttle and RPM position. Link->http://tuneboss.co/
    4. Final drive ratio is more of a self preference, and will usually depend on your riding style and your machine capability of course. I myself is still using a stock ratio of 3.0. But 15-42 or 15-43 is liked by many.
    5. Use a standard spark plug and ignition coil, changing it will only affect like 0.5% of the total performance, no point. While for air filter, any racing air filter will do, more airflow, and money saving in the long run, due to it being washable, thus reusable.
    You can easily achieve 150+ kph gps reading with this setup:
    1. Uma 62mm block (62 instead of 65mm for longevity reason, daily use right?)
    2. Uma Superhead 20/23 (An original head with a port and polished intake and exhaust port will do as well, normally come in 19/22 size, CMS and BRT brand are famous)
    3. 160cc injector
    4. 32mm Throttle body
  12. mxking035
    mxking035 Member
    Feb 2, 2016
    311
    88
    56
    thats right, correction for stack valve spring is 13.1k rpm limit, Im using UMA VSpring now
    I also used big surplus Multicab Coil for more than 1 year (realy good coil but sadly damaged and can't find same coil) I boughy new multicab coil and after 2month I removed it and used the stack, then now to faito coil
    My combi is 42/15 better than 42/14 for my mods, did not try yet for 43/15
    for sparkplug
    CPR8EA-9 is better for daily use than stack CR8E
    but CR8E is better for long drive than CPR8EA-9
    not yet observed well which is better that iridium and CR8E for drag, but for sure CR8E is good for spark advance at higher rpm in my experience
  13. meonk moi
    meonk moi New Member
    Jul 2, 2017
    Indonesia
    for standart engine use yamalube king
  14. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    S
    Standard engine or any engine will benefit from a good oil. Use any brand's top of the line.
  15. Zulu
    Zulu New Member
    Jun 4, 2017
    19
    I tried Mobil super 2000, engine runs smoother and cooler than yamaha synthetic. Cost 305
  16. Boss ej
    Boss ej New Member
    May 3, 2016
    38
    19
    Ive used castrol yamalube shell yellow blue, pertua and im happy with the shell blue one..
