Coolant Leak.
Discussion in 'T150 & T135 General Topics' started by jeffrey14, Feb 17, 2014.
  1. chrysler cayabyab
    chrysler cayabyab Super Veteran
    Mar 1, 2012
    300
    41
    pasig city
    naghahalo n kc un coolant q tska langis s makina q... un mech q nman s 3s ngsbe kung anu ung dapat palitan... nakita q nman nun binuksan nmen...
  2. guitarizta
    guitarizta Super Veteran
    May 14, 2008
    948
    158
    Angeles City, Pampanga (15.148526,120.59945)
    sir @astridnoelle how is your mc now? did you already solve the whistling sound?
    sir @jeffrey14 did you encounter a whistling sound also before you repaired your mc?
  3. Yssien Bryl Santillan
    Yssien Bryl Santillan New Member
    Jun 27, 2014
    52
    9
    Cebu
    guys bago lng po ako ng register..problema po kasi ako sa sniper ko e..yung thermostat indicator po minsan iilaw tapos mawala, blinking perhaps..tinignan ko po coolant ng radiator, hindi namn nabawasan, bale above low point pa yun mula nung binili ko pa, 2nd hand kasi e. hindi ko dn po sya na tune up mga 4-6 months..ang prob po ngayon e parang ang bigay ng motor ko pag tumakbo, parang nabibigatan habang ng re-rev ako e.at saka sobrang gastos sa gas.50 per day e amf. ang byahe ko ang lapit lng.noon 50 every 2 days..
    please po patulong naman nito..pa tune up ko po ba or coolant?
  4. jeffrey14
    jeffrey14 New Member
    Oct 10, 2013
    50
    12
    angeles city
  5. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    yes sir, i tot its just only normal,, but when i open my waterpump i found bearing is jam causing impeller not perform his play thas why oil seal slowly damage the lips..
  6. mark anthony landayan
    mark anthony landayan Veteran
    Jul 16, 2013
    608
    100
    153
    Nueva Ecija - San Isidro
    wow that oilseal is too expensive
  7. Yssien Bryl Santillan
    Jun 27, 2014
    52
    9
    Cebu
    guys can i ask for help with my MC...i search in youtube how to change my coolant, i also already know how to do it..but one thing im confused, what to do on reservoir? the one below the belly pan.as of now i haven't changed the coolant yet, the coolant level in the reservoir is below "low" point, now the question is do i need to get rid of that coolant in the reservoir? and another question also, if i'm going to get rid all of the old coolant in the radiator and reservoir, do i need to pour new coolant in the reservoir? or radiator only?
  8. kikaipitoy
    kikaipitoy Super Veteran
    Apr 10, 2009
    1,825
    207
    Angeles City
    if you really want to change your coolant, you can do that both on the radiator and reservoir, and you can also just add if you want to...at the radiator side just open the radiator cap then remove the nut (facing the radiator) on the cylinder wall to drain the old coolant then replenish it with a new coolant. Same goes with the reservoir just observe the suggested level of coolant....hope this helps....tnx
  9. Yssien Bryl Santillan
    Jun 27, 2014
    52
    9
    Cebu
    thanks bro..
  10. john_carlo
    john_carlo Super Veteran
    Sep 4, 2009
    3,308
    665
    14°28'51.29"N 121°11'37.66"E
    my bike is 6 years but my coolant is been change 3x not for maintenance but for a leak in water pump and head gasket... use a pre mix when changing..
  11. astridnoelle
    astridnoelle Veteran
    Jun 24, 2009
    120
    29
    143
    Pateros
    Good day, sir chrysler.
    2 years ago i posted on this forum about coolant leak,& now im in neck-deep water na.. may i know if there are other shops that sell the water pump parts, or even the entire water pump itself? im kinda looking for alternatives to repair the necessary components only, but my x1r is almost 7 years old, & im also looking to replace the entire water pump assembly. yamaha yzone in ortigas quoted me at 4,122 pesos (most probably part-per-part total price)for the water pump assembly last 2014, & i cant go back there due to work. if you can provide some assistance, it would be most welcome.
    Thanks & Ride Safe!
    snipermxmalayaklan likes this.
  12. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    Good day, sir Christian!
    In line with the queries on this forum, do you know where I can buy the other parts for the water pump, aside from yamaha 3s shops? i need to replace parts of the pump, but i also might need to replace the entire pump itself.
    Thanks & Ride Safe!
    jangbest likes this.
  13. jangbest
    jangbest Moderator
    Nov 9, 2010
    5,565
    3,283
    GMA Cavite
    On Facebook For sale section there is selling water pump assy. 2nd hand
    but if you want brand new parts and not Going to Yamaha 3s due to your Busy Schedule I can Recommend you a seller that Trusted on selling OEM Part he is @Jon Hernandez ,
    but for me it doesn't need to replace all your water pump assy. the parts that was really need to replace was Water pump oil seal, Impeller shaft and Impeller Shaft Bearing.
  14. maized30
    maized30 New Member
    Oct 15, 2011
    71
    11
    mandaluyong
    up for this post!!!!
