Coolant Leak.
Discussion in 'T150 & T135 General Topics' started by jeffrey14, Feb 17, 2014.
  1. jeffrey14
    jeffrey14 New Member
    Oct 10, 2013
    50
    12
    angeles city
    need help... coolant always mix in engine oil, i think i need 2 change my oil seal, any idea how much it is? or does any available other brand? or need to change my waterpump assy? any suggestion pls?? TIA.
  3. chrysler cayabyab
    chrysler cayabyab Super Veteran
    Mar 1, 2012
    300
    41
    pasig city
    1600 kkpalit q lng kanina s 3s mismo aq bumili
  4. astridnoelle
    astridnoelle Veteran
    Jun 24, 2009
    120
    29
    143
    Pateros
    Sir/s:
    Which is 1,600? waterpump assembly? sir jeffrey, check ur water pump assembly first... just three 8mm bolts (use a t-wrench) to remove. i believe there is an asbestos gasket or similar material right behind the coolant impeller. this is naturally in contact with engine oil because it slots into the gap on the timing gear of the camshaft. if you can open the water pump (4 pcs 8mm bolts, i think), you'll see that it has a "pocket" on theright of the impeller side, which is where the coolant actually circulates. i'm honestly unsure if that such "gasket" can be replaced as is, or if it is part of the entire water pump assembly. check with the other experts here to verify. hope that helps.
    jefplacido likes this.
  5. chrysler cayabyab
    Mar 1, 2012
    300
    41
    pasig city
    oil seal lng binili cost 1600.. maliit n parts lng un... un lng cost nun kya ngleak
  6. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    sir chrysler, first palit mo palang ba? dati kasi nagpalit nako , may nabili ako 180php lang, ano kaya pinagkaiba nung dalawa? 1600 vs 180?
  7. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    sir astridnoelle, tnx for the info.. i'll check it later after work..
  8. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    ur welcome sir jeffrey. i'm curious about that oil seal hehe.. it's kinda expensive.. last year i repaired the gasket on my water pump.. the bottom part of the gasket (on the coolant hole or whatever that is) was eroded, so i was slowly losing fluids.. i took the pump out, scraped the rubber on the gasket so the thin metal gasket was exposed, cleaned it up & used gasket maker. never leaked again hehe.
  9. Christan Bernardo
    Christan Bernardo New Member
    Jan 21, 2014
    11
    5
    Bulacan
    you can get replacement water pump seal from Simplex in Caloocan or Sta. Cruz Manila, cost me only Php 260.00. Just give these measurements to the attendant 10x31x13.5
    jefplacido and astridnoelle like this.
  10. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    sir christan, is there any other branch of simplex located in pampanga area? tnx..
  11. Christan Bernardo
    Jan 21, 2014
    11
    5
    Bulacan
    sorry I didn't see you're from Angeles. I don't think they have a branch in Pampanga. You can check out any local oil seal centers in your area... Just give them the dimensions they might have it...
    gymi likes this.
  12. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    PROBLEM SOLVED…!! The main problem is the impeller shaft, I found a lot of scratch in it that’s why it slowly damage the lips of the oil seal, yesterday I went to 3s shop after work, im lucky they have a stock of oil seal, but no stock of impeller shaft, until try to LC shop, they have a stock but a lil bit high price than yamaha 3s. after 2hrs rest when i got home i start the scenario. CIMG1504.JPG CIMG1504.JPG CIMG1503.JPG CIMG1496.JPG View attachment 29209 View attachment 29208
    BigBird and zcbitik like this.
  13. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    Tnx to sir chrysler and Astridnoelle for info..
    astridnoelle likes this.
  14. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    Ur welcome sir jeffrey! Good to know ur bike is in good shape again.
  15. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    Sir jeffrey,
    Would you mind quoting the prices of the parts that you replaced? Thanks!
  16. jeffrey14
    Oct 10, 2013
    50
    12
    angeles city
    impeller shaft assy = 630
    oil seal = 1600
    bearing = 130
    yamaha 3s impeller is only 491php. but you need to wait up to 4 weeks.
  17. BigBird
    BigBird Super Veteran
    Feb 8, 2014
    389
    148
    San Fabian, Pangasinan
    Watch mode......
  18. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    Sir jeffrey,
    Thanks for the quotation. I'd like to say.. ouch! a bit expensive hehehe.. + 1 month wait. If ever, I might have to pre-order since I ride my X1r everyday.. got 43k on my odometer already hehe.. what brand is the bearing? I'd have to ask my uncle's shop if he got NSK bearings of the same size hehehe..
  19. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    sir jeffrey,
    my x1r currently has dis problem: when the engine has reached a certain operating temperature, i get a high pitched continuous "whistle" from my water pump. this goes away as soon as d engine is revved, but whistles again as soon as d engine rpm goes back to idle... could dis be a worn bearing? thanks for d response.
  20. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    sir chrysler,
    what was d reason for d oil seal change that u did? same with sir jeffrey or same as what i last said (re: whistling sound)? i had opened d water pump today & i saw a faint line just behind d impeller shaft. do u have to take d oil seal replacement to a machine shop to have it pressed? or is it DIY? thanks for ur help...
  21. astridnoelle
    Jun 24, 2009
    120
    29
    143
    Pateros
    to all concerned,
    i checked with Yzone Ortigas... the entire water pump assembly costs 4,122 pesos.. ouch hehe.. need to make repairs first to avoid this big an expense..
