sir,may suggestion ka jettings for stock bore for my SWR 28mm?tia!62mm,22/20,stock stroke, 0.006-0.008in-out, cam regrind,1&6/8 turn, Sunworld 28mm D carb, open carb,
112/37=waswas mode,
110-108/37=traffic mode iwas sinok. this is my jetting po.
112/37=waswas mode,
sir,update with your carb po?same2 po tau ng set.up. .stock bore?Sir can you help me with thw right jettings for my swr 28mm carb..pitzbyke rcdi,hi speed v.springs,faito racing coil..14-40 sprocket combi..im aint satisfied with its performance..my snipy vibrates a lot..wew..help sir..any auggestions..tnx a lot..
upsir,may suggestion ka jettings for stock bore for my SWR 28mm?tia!
upsir,update with your carb po?same2 po tau ng set.up. .stock bore?
quick question dose it heat alot ? i mean like can you feel the heat on your foot when driving kinda heat.Need some help guys..
Currently on CMS 63mm , stock header
keihin 28mm Carb
Hi cam.
Sprocket if not wrong 16/34.
Leo vince sbk pipe (without silencer)
Previously using keihin 26mm carb 150mj 42pj.
Top was smooth and tiptop. Now changed to 28mm top feel heavy.
Guys can help?
If i want back the same setting on the 28mm carb .. What mj n pj size should i use?
sir do you know what jet size of my sniper mx 135 ?@elyouch
above jettings just works for me.
@pototoy
i never write down of my expenses
others please share your jetsizes
AFAIK on the manual mikuni BS25 MJ is 115 and PJ is 15s
i havent tried 28mm carb, but you can buy one jet size at a time.Spec V high comp
Stock head
V springs
Stage 2 cams
28mm flat carb
Patulong po sa recomended jet size po pag low rpm pumapagakpak yung sniper classic ko pero kung average to full throttle okay po siya. Help po ty. Ps meron din pong smoke ang exhaust ko after setting my carb.
need help guys
62mm bore flat piston
stock head
stage 2 cams 5.8lift
racing v spring
rdci
sprocket combi 15/38 snpy classic
28mm SWR flat
40 120.... very low mileage (sobrang takaw)
sunworld, really drinks gas. mine's 28mm sunworld can accomodate only 60kms in 1 fulltank even i rejetted it already. I plan to change it to different carb. Was your head fully stock or ported cause as what the other thread told is the last safest bore for fully stock head was 59mm
tnx newbie here
Thanks sir hehei havent tried 28mm carb, but you can buy one jet size at a time.
also follow the tuning manual of carbs here
http://www.yamahat135.com/threads/mikuni-carb-tuning-manual.19336/
There are different causes sir but the usual is your carb needs cleaning or your manifold has a hole even smallcan i know the fix for idle high and then suddenly dropping
